Old 07-11-2011, 08:38 PM
Default Work on a K301 12hp Kohler
Just wondering if it is possible to re-thread or helicoil (sp?) the front two motor mounting bolts on a 12hp Kohler. Thanks in advance for your comments!!
Old 07-12-2011, 11:07 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Yup you should be able too, i put helicoils in an aluminum pan for 2 of the mounts for my 1250 still holds without a problem.
Old 07-19-2011, 08:00 PM
elbertjolley elbertjolley is offline
Probally will last longer than just running a bolt into the alum threads like the factory way
Old 07-19-2011, 08:55 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
It should work well if the hole isn't too wallowed out.
Check the hole size by drilling with the correct bit for your helicoil. You should have all fresh cut metal on the walls.
Countersink the hole slightly, and install the helicoil so the lead thread is below where the countersink ends. Use 1.5 Diameter helicoil at least.
Be sure to break off the tang and retrieve it. Very important step.
Good Luck!
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 07-19-2011, 10:00 PM
Thanks guys!!! I am missing my front two bolts on my engine mounts and now I know why. I spoke to a local mechanic and he said something about maybe sleeving it, but I'm not 100% sure on what he was talking about so I will need to look into the matter some more.
Thanks again,
Old 07-19-2011, 10:16 PM
william1041200's Avatar
sleeving it would be to drill out the hole to make it smooth and round, then press in a threaded sleeve, or a solid plug then drill / tap it. I would prefer helicoiling it. Just don't drill past existing bottom of hole.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
