Old 07-02-2011, 03:54 PM
FJK12 FJK12 is offline
Default Carb Problem on 1250
Worst possible time, holiday weekend everything closed fo cc parts.
Cutting the grass last night, engine starts to stumble, loose power, & dies. If i raise the cutters & take the load off the engine, I can drive back to shed. I aslo can restart, but does not like to low idle.
Today, pulled it apart, air cleaner has alot of liquid gas in element, but tractor would start & run. In the garage, I'm running engine at wot with air cleaner removed & it looks to me like too much liquid fuel is entering the air stream. I'm thinking debris on the needle & seat. Problem is, if I pull the float bowl off, I don't have a spare gasket & o-ring, & I recall your'e kidding yourself trying yo reassemble with the old stuff. I maybe wrong, but I would like other opinions. Also, could this be a vent or adjustment problem?
Thanks, FJK
