Some shots of the 147 deck I did over that last several week.
Had to by a lot of the parts as they were removed for another deck, the 48 inch deck on Eric's 147. Thjis was his original deck for that tractor which PO put a 48 inch on. So this was a spare deck. Replaced idler pulley, and idler spring. Had to buy used spring hitch brackets. Fabed new right wheel bracket PO lost it when the corner of the deck rusted and broke off. PO had to bring me the left runner bar. Right runner bar was at my sons Center pulley had some issues from PO. Had to add a custom " Key " to secure the pulley to the shaft. New belt Some steel cutting, welding, and custom stainless work underneath too. Should they be junked when this bad??? Maybe? This one should have several years left in it now! A good down and dirty get it done project! Rustolium Ivory and OLD CAT Yellow are the colors. Rattle cans. Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
Chris that is amazing!
doesn't ever look like it was even close to being rotted away. looks awesome! i have to get going on my Original deck.
VERY impressive work!
![]() -Mark 1978 1450 1976 1450 |
Looks great! I wonder what caused that end to be rusted so badly...they must have stored it next to the sewage lagoon and that end was submerged!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
Wow! Nice job Chris.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Beautiful work on the deck Sugarmaker
Probably a combination of wet grass clippings that were not cleaned off, and the gauge wheel on that corner doing its job until the rust from problem #1 weakened it enough for it to break off. This is a pretty common problem, and why it pays to frequently clean off the underside of the deck.
Amazing job on the reconstruction. I can't believe it is the same deck.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
WOW!! You sure had your hands full with that project. Very nice job
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
