Old 06-27-2011, 09:32 PM
Default still have 1250 trouble
Well I had it running , but like I said it wasn't pretty. It would really start hard, turn over fast and catch every now and again. Once it starts the whole tractor would shake a bunch and smoke out the breather and muffler.
So today I rebuilt the carb. it wasn't in good condition at all. Cleaned the breather and replaced the old gaskets, and while I had it off checked the valves and adjusted. Checked the points, they were fine.
Went to start it, same thing.
Seems like it wants to start right up, but it won't. Crank it and crank it and it will like sputter, then nothing. Try again and it light up but runs rough again.
Any ideas? I'm thinking this one saw a rough life by the way it's going.
Old 06-27-2011, 11:29 PM
Southtowns27's Avatar
Southtowns27 Southtowns27 is offline
Try resetting the timing using this procedure: http://mgonitzke.net16.net/tools/static_timing.pdf
Old 06-28-2011, 10:11 AM
Originally Posted by Wild Bill View Post
Sure sounds like the timing is off to me
Do you have a timing light?
No Bill I don't. But now early this morning before I left I tried starting it, nothing, it just putters. I'm confused! (But we knew that, didn't we)
Old 06-28-2011, 10:47 AM
Donovan M.'s Avatar
wires on the coil on backwards. mine were after i put the engine back in to replace the cooling fan.
Donovan:
62' Original-fenders
Old 06-28-2011, 11:24 AM
Nope, I'm sure I put them back in the same order, and the same as the other tractor sitting next to it I used as a refrence. Now you got me re-thinking myself I'll check when I get back home.
Old 06-28-2011, 10:16 PM
Well I'm man enough to admit I'm sometimes not the sharpest knife in the drawer. I had the power wire and points wire on backwards.
Put them the way their supposed to be, and it fired up Can anyone say dumb...?
Live and learn I guess. It smokes blue real bad, so I'm thinking theres a whole lot more wrong than just two wires on backwards. But I sure do appreciate all the help. Thanks
Old 06-29-2011, 01:38 AM
CC1650Dave's Avatar
Donovan with the score!
Imagine how long it would've taken to figure that one out without having access to this forum. What a great resource.
Old 06-29-2011, 05:18 AM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default 1250 trouble
Happens to the best of us, very nice that someone came for the save. Crank her up.
Donny
Old 06-29-2011, 10:36 AM
Todd that's awesome news! Don't let it bother you it happens to all of us.
Old 06-29-2011, 11:53 AM
Ditto!
