Old 06-26-2011, 09:19 AM
cubcadet147 cubcadet147 is offline
Default 147 oil capacity question
i have a 14hp kohler k321a engine on my cub cadet 147. i checked the oil dipstick and nothing showed up so i added oil and checked the dipstick regularly and basically ended up putting a full 2qt in. the tractor starts fine and idles good with the throttle low to halfway but any higher it starts to die so i quickly lower the throttle. so my question is what is the oil capacity so i can drain the oil and start from scratch because i've also not done an oil change in it yet.thanks in advance.
Old 06-26-2011, 09:41 AM
MOturkE's Avatar
MOturkE MOturkE is offline
http://ccmanuals.info/pdf/1x6-7%20Op...20Manual-2.pdf
Just looked at page 30 of the operators manual here and it says 3 pints of SAE 30.
Proud to own a 1965 Cub Cadet 122.
Old 06-26-2011, 10:14 AM
thanks, ill save that manual to my computer
Tags
k321a, oil capacity
