Old 06-20-2011, 08:11 PM
Tool Maker's Avatar
Tool Maker Tool Maker is offline
Question Trying to Replace a Rusted Muffler?
I am trying to get an old rusted/rotted muffler off of my 100 and have been soaking it 24 hours so far and the threads are still froze tight. I am using liquid wrench penetrating oil. At work we use kroil and pb blaster. Might try one of those unless anybody here has any suggestions. The pipe is also threaded/screwed into the engine (no bolts). I was going to just replace the muffler, but if its easier I can do the whole thing. Basically I need help. thanks guys!
Cub 126 w/creeper & lift assist, IH wheel weights, Rear Lift, 10" Plow, IH front blade, QA42A Snow Thrower
Cub 149 w/48" mower deck, wheel weights
Old 06-20-2011, 08:14 PM
When did you get a 100?
You might have to add some heat to it.
Old 06-20-2011, 08:17 PM
Tool Maker's Avatar
I got it off this really nice guy who told me if I buy one I get another free. He is going to give me a model 71 Your the man Duke!
Old 06-20-2011, 08:20 PM
Ummm have you been sniffing PB blaster again? I got a feeling we'll be seeing each other pretty soon for another load.
Old 06-20-2011, 10:59 PM
william1041200's Avatar
If you apply heat to Duke's butt he may give in to the 71 demands.. If you apply heat to the exhaust elbow, it may give in to your demands of removal... Good luck !!
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 06-20-2011, 11:36 PM
Oh my!
Old 06-21-2011, 09:31 AM
Here's what I did to get a very stubborn muffler off of my 7hp from an old 73. Spray PB blaster in the little front holes of the muffler (BE SURE TO WEAR PROTECTIVE EYE GEAR!!!) and give it a good soaking a few times. Also spray the back threaded side as well. Work it forward and backward a little at a time with your hand or if you do not wish to save it you can use an oil filter wrench. Eventually, you should be able to get it turned off by hand.
