Old 06-14-2011, 08:09 AM
cdlong's Avatar
cdlong cdlong is offline
Default Tire sealing problems
I have several aftermarket attachments, trailer, 4 wheeled hose reel, spreader, aerator and dethatcher. All have plastic wheels with rubber tires except the trailer, those wheels are steel. There are no tubes in any of these tires.
I find that after several weeks of sitting, not being used, the tires are flat and seperated from the wheels. To inflate, I use a ratchet strap to pull the sidewalls back to the wheel and inflate.
My question: is there a way to "seal" the tire sidewalls to the wheel, or do I need to install tubes?
Thanks
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
