Old 06-01-2011, 10:19 PM
Default Wiring on a 129
Hello...I have a quick question about the wiring on a 129. The PO wired in a different selonoid than on my other 129, this one has the main post vertical (top and bottom). Which one does the main wire from the battery hook onto....the top post or the bottom post? I was rewiring it and didnt't think to check which one I took it off of--but my best guess is the bottom one, just not for sure. Thanks in advance!!
Old 06-01-2011, 10:44 PM
It shouldn't matter. The smaller post applies current from the key switch to the magnetic solenoid which will then connect the two big posts thru an internal switch allowing current to the starter.
Old 06-02-2011, 01:15 PM
Okay, thanks DX3!!! I appreciate the help.
