let me know if pics are too big.
![]() didnt get camera lense cleaned but you can see :P guy who painted it before me didn't know how to paint, overspray everywhere possible. ill replace first picture in bit with a better one. ![]() i do have the grille just need to get some bolts to hold it in. however questions for parts that are messed up ![]() pretty sure this is suppose to be flush agianst mower deck? maybe? maybe not. missing spindle shield on both sides... gotta pick those up. heres a good question. bearing for idler is gone ![]() easier to just buy new or get a bearing and press in? ![]() the stud with washer does it do anything with the spring? or is it for the spindle shield. the spring is all loosey goosey. would love some pics of the 42" set up so i can see what i need to fix / do need tuck the wiring ![]() ![]() missing the shield there also. *do not ask about the coil wire* ![]() ![]() thats all for now. ill get some more up later. |
this is how they fixed the hood
![]() gonna try finding another hood then ill fix this one when i can. ![]() ![]() prolly just wore through so they decieded to just rig it up? and this lil deal they added to the chute side of deck ![]() i like it when close to the house or if pet outside. but if not it just flips over and sits on the deck. kinda cool. but def added on. |
Yup, pictures are a little big.
Nice tractor though, PO could use a lesson in wiring, less is better ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
first picture fixed
sorry ill resize them when i can. my laptop is hooked up to a 24in LCD so they look smaller to me. but next time ill have it fixed. the wiring i plan on doing, i want to order a set of lights for the front. forgot what webpage but they hook off the side instead of into the front where they would be. but once i get that ill rewire everything. its run good but carb needs to be cleaned and adjusted. ill start work on that after i get the mower in good shape. need buy belts and whatever i need to fix the mower. |
Congrats on the 126. Have fun fixing her up. Hope to see more progress pics.
so with the tensioner pulley...
ive been looking through sponsers and a couple other places i found. cant seem to find one? i pulled the pulley out... no bearings left in it. looks like the bearing is put in then pressed in... so its a throw away and buy a new from what im seeing... too bad u cant just pop a bearing in there. |
Try NAPA, they should be able to get what you need. Take the old one in with you so they can verify the size. Unless you actually call or email the sponsors you won't get a true account of everything they have in stock. What is listed on their websites is usually a small amount of parts that they have available.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
hey Soaper
that hood is an easy fix. I took mine to a body shop and they welded in a new corner and reinforced it with washers inside and out. they smoothed it out and i fared it in with bondo. total fix on both sides cost me 40 bucks. |
i dont think napa could match it could they?
i found it on one website 18$ still looking though. gotta order a spring cause it broke where it mounts at bottom. but yeah its basiclly if it fails. toss it and order a new one... cant redo the bearings from the looks of it. |
Congrats on your 126!
