Old 05-27-2011, 08:48 PM
bkeicks bkeicks is offline
Default 301 carb question?
I finally have my 125 w/K301 running but when installing the carb after rebuild I started thinking I am missing a spacer between the block and carb. There wasn't one on the motor when purchased.
I checked the Kohler parts lookup but can't see one there either.
Old 05-27-2011, 09:27 PM
Your missing the gasket. Be careful when you order one I got a thin one when I ordered mine last year.
Old 05-27-2011, 09:28 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default spacer
My 127 had the plastic spacer on it when I got it. They are aftermarket I believe and have a built in gasket on each side. When I redid my carb, I did not use mine and just have the carb and gasket. Works fine for me......
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 05-27-2011, 09:43 PM
ljones's Avatar
ljones ljones is offline
You can buy aluminum spacers to help engine heat from radiating into the carb, but the spacers were not factory.
Old 05-27-2011, 10:31 PM
red211's Avatar
red211 red211 is offline
I got a small bakelight spacer with the gskts on both sides from dealer, it is a kohler part, just not sure of the number. Not sure if it was for those engines, but it fits fine and worked good.
Old 05-28-2011, 05:19 AM
right on Guys, I sure do appreciate you all chiming in!
Old 05-28-2011, 09:43 AM
TEET's Avatar
TEET TEET is offline
You could make out out of gasket material as well easy enough. The early Kohler's had a gasket only then they switched over to the spacer/gasket setup later on. I've had no issues with either, but I believe the spacer was introduced for thermal reasons.
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
