Thread Tools
Display Modes
I am new to this and not sure I am in the right place. I have a 782 that will start and run but not very well. When sitting on the seat the plug on the right side is black, really black all over. I put a spark tester on both plug wires, then connected them to the plugs. It looks like I have a white spark to both plugs. I thought I would have a blue spark. The spark to the right side is harder to see. It looks like the plug wires and coil are all orginial. I have though about replaceing coil, plug wires, points and condenser. Anyone have any suggestions? Oh, I do have new plugs in it. What should the points be set at?
Your KT17 has a broken rod.
782 w/Honda power 129 stock for now... 100 basketcase |
I agree. Compression test it. (put thumb over spark plug hole and crank)
Tyler Chiliak. Southeast Alberta Canada. My dad and I own, 1650, , 1450, 1250, 1250, 1200, 982, 782, 149, 149, 149, 128, 128, 123, 100, 100. Also a 1310, 1500, and 2 1600 IHC trucks. |
I am not disagreeing ,and I am always wanting to learn. But please explain to me how you can tell that an engine has a broken rod from the information the poster has given us.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
If it did have a broken rod would you not hear a massive knock?
well my thought is that since its a twin it would continue to run with 1 completely broken rod but only on one cylinder. there would be no knock because the rod is completely broken. im not sure if he has a broken rod, but i agree that a simple finger over the hole test would confirm of deny a broken rod. take spark plug off of other cylinder while doing test test. test at cranking speed more than fast enough.
If you confirm the rod isn't broken, replace the points, condenser, and wires. I had a similiar problem on a 782 and it was the coil.
Adrian 2072 (789513) |
Is it common for these to break the right rod?
I just replaced the HG and that didn't fix it. I turned over the engine with the head off and the piston didn't move.. ![]() I hope this is an easy fix???? .. |
That's a typical failure mode, but it doesn't necessarily have to be the right cylinder.
If it's a series I, keep the carb, jugs, heads, and pistons (if they aren't shot), and scrap the rest. If it's a series II, you can rebuild it but you'll need two new rods, main bearings, governor, gaskets, etc at a minimum, assuming the rod didn't take the block, cam, or anything else with it. I have never taken a blown one apart that didn't have block damage. The only way to know is to take it apart and inspect it. |
Thanks for the reply Matt.
Its a series II. If there is block damage, can I just replace the bad part and use the rest. I see the block is two pieces. I also have a window'd series I. Would that block work or anyof the parts? I have looked and there are no cheap series II's for sale to replace it. ![]() .. |
