How do you hold the K301 flywheel to loosen/tighten the flywheel nut? I know that the Service Manual says to use a strap wrench, but I don't believe that is possible, since the blower housing and grass screen/drive pulley are installed before the flywheel nut is installed.
Any ideas? Thanks GEL |
I use an air gun to remove the nut,no need to hold the flywheel.Try a sharp blow on your ratchet handle to break it loose with a strap wrench on the other end of the crank.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains 106-42"deck 1250-44 and 50" decks 147-44"deck 2155-42"snowblower 38"deck, chains,suitcase weights Exmark Quest-zero turn 42"deck 23hp Kawasaki engine |
I put a strap wrench on the pto basket when I did mine.
Web Developer - Need a website? Contact me. |
Years ago I had a 102 project, I do not recommend using an air impact on the nut that holds the flywheel on. I tried this myself on that project and got to add the cost of a new crank to the build. It sheared off the entire threaded portion of the crank, back then a new crank was $160 or so, now they exceed $400.
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
does it have a flywheel gear on it. If so use a pair of locking pliers on it. Use a harmonic balancer to remove it. You might have put pressure on it with the puller then tap it gently with a hammer. Should pop right off.
When I did it I practically had to stand on it. Some are easy, some aren't.
