Old 05-25-2011, 06:43 PM
krhoover krhoover is offline
Default fluid change
I have posted a few times about the 1450 i got recently. The next question is, I think the trunion may need worked on but was going to change fluid and filter first as I don't know when it was changed last( the filter on it is yellow, if that tells you anything). The question is, if the fluid change dosn't help, will I have to change the fluid agian to do anymore repairs, am I wasting my money on the fluid change now if I have to to work on the trunion later?
Old 05-25-2011, 06:53 PM
westofb's Avatar
westofb westofb is offline
Nope, you can go ahead and change the fluid/ filter, if it requires work to the trunion, it is mounted externally on the hydro pump. It is a lot easier to repair them if you spilt the tractor, if you do this and your tractor has a ported pump (hydrallic lift) you might loose a little bit of fluid from unhooking the lines to the hydrallics, but should be a minimal amount, just re top it off after putting it back together.
Jeff
Brookfield, MO
________________
Old 05-26-2011, 06:23 PM
Thanks for the help
