Old 05-22-2011, 10:02 AM
7dale3 7dale3 is offline
Default 1864 pto won`t stay engaged ?
I recently Purchased this tractor with a blown Head Gasket, that i replaced. But the next issue is the Pto will not stay engaged.If i hold the switch up the mower runs great. I first tried a new switch, but no cigar.Battery is new. Pto is getting between 12.7 and 12.9 volts when engaged but when i release switch it dis-engages. There is no wiring to rear, it was all cut in the tunnel. I tried another 5 pin relay still the same. I set the air gap to .015 and it still will not stay engaged. I`m sure the problem is something very simple to repair but am i missing something? Any thoughts would be greatly appreciated...
Old 05-22-2011, 10:13 AM
Your problem with the PTO could be one or more of these things:
* Bad Reverse Relay
* Bad Reverse Switch
* Bad Seat Switch
* PTO Switch
Wiring Diagram sent to the E-Mail addressed list in your profile.
Old 05-22-2011, 12:29 PM
Default 1864 pto update
Since i tried or bypassed all of these potential causes and since the previous owner got overzealous with his wire dykes. I was at wits end checking wiring or bypassing switches, relays and checking voltage to pto coil and adjusting air gap as well and PTO still would not stay engaged after releasing switch. I did what any other Red Blooded Mopar/Cub Cadet man would do and that is to run an inline barrel Fuse from the purple wire at the PTO switch to one of the red and white wires on the back up relay. And now it works only with key on and as soon as switch hits the center position. Just got done Mowing with it.
Old 05-22-2011, 12:57 PM
Brim Reaper's Avatar
Brim Reaper Brim Reaper is offline
Cool
My 1330 did the same thing until I replaced the PTO switch but getting back in service any way you can is the objective. Us MOPAR men can be real crafty sometimes out of naccessity ( 1977 Power Wagon ).
It's not what you buy but what you build
