Old 07-11-2009, 02:41 PM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
Default Newer deck on a 1450
I was just wondering would a deck off a 1864 work on a 1450? It is a 54" and the mounts look the same. The only thing i see different is the 5/8 belt pulley on the deck and a 1450 takes a 3/8" belt. I've also seen some 60" decks that look the same. Thanks
Old 07-11-2009, 08:30 PM
The mounts are similar, but it won't fit right under there. The front tires will probably hit the front edge of the deck, and I'm not sure if you'll be able to raise it all the way. Stick with the 44A and 50A decks.
Old 07-11-2009, 11:24 PM
Thanks Matt G.
