Old 05-11-2011, 08:12 AM
CaptMax's Avatar
CaptMax CaptMax is offline
Default Restoring or replacing a Stedi Seat on a 102
I have a 102 Cub with a nice seat except for some black stains from sitting outside too long. Are these available or how should I clean mine? I tried a couple products and nothing has touched it so far. I wondered about using a paint for vinyl such as used in the automotive industry. Has anyone had any luck getting them white again? Thanks for your thoughts.
CaptMax
Old 05-12-2011, 04:19 PM
CaptMax's Avatar
30 views and no reply? Come on guys......someone has had to run across this before.
I would be interested to see what others have done when confronted with this. I hate to just put a new cover over an old problem.
Thanks, CaptMax
Old 05-12-2011, 05:25 PM
gcbailey's Avatar
gcbailey gcbailey is offline
have you tried some bleach? I would go with oxyclean, purple power, blue wolf, greased lightning... all at full strength. How about some concentrated cleaner for pressure washers? Do you have a pic of it?
Gary
Old 05-13-2011, 02:05 AM
I've heard people using paint but it cracks and you've got to keep redoing it over and over.
Old 05-13-2011, 08:31 AM
CaptMax's Avatar
I will try and get a picture posted so you can see it's condition. As far as painting goes, I would use the vinyl automotive paint with a flex additive such as used on the urethane bumpers these days. Anyone have an new old stock seat they will part with?
CaptMax
Old 05-13-2011, 04:56 PM
B-Brush B-Brush is offline
my 102 seat was covered in dark almost moldy like spots i used soft scrub kitchen and bath cleaner and scrubbed the heck out of it then sprayed it with a bleach and dish soap mix let it sit a while then scrubbed again i did this over and over until the rubber was clean it worked very good but takes a whole lot of elbow grease !!! hope this helps
Old 05-13-2011, 05:00 PM
CaptMax's Avatar
Yes, that are the symptoms it has. I will give your advice a whirl and post before and after pictures. Thanks!!!
CaptMax
Old 05-13-2011, 07:30 PM
cuber cuber is offline
Go out and get some cleaner that is called Krud Kutter. You can usually find it at Menards, Farm & Fleet, or Fleet Farm. The stuff works really good!!!
Old 05-13-2011, 08:06 PM
CaptMax's Avatar
Well here is the before pictures.....I'm still scrubbing and will try the Krud Kutter as well. I think it will need all the help it can get!
CaptMax
Old 05-13-2011, 10:29 PM
Looking forward to your progress!
