Old 04-25-2011, 08:14 AM
steveyrock's Avatar
steveyrock steveyrock is offline
Default k301 governor
Hello
I need opinions on just replaceing the governor in a good running k301.Motor does not smoke or knock,runs strong.The governor is shot and I need to tear it down to replace it.Don't want a do complete overhaul as it runs so good. This motor is in a 1250 and it would be a good time to get rid of the balance gears while it's apart.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
Old 04-25-2011, 09:19 AM
I would see nothing wrong with just replacing the governor gear. While you are in there go ahead and replace the governor cross shaft too. It will be a good time to de-carbon the head too. All you will need is a gasket set.
