Old 04-24-2011, 10:29 PM
jmroy's Avatar
jmroy jmroy is offline
Default Found an 800 in hiding
Picked this up tonight, no model number on it as a lot of it has been repainted at one point but I was able to find the K181 Kohler tag. It's missing the side panels, the air cleaner and cover, and the ignition switch. It looks like the original starter has been replaced. It does have what I believe is the original muffler and surrounding sheet metal, electric PTO, deck sub frame (no deck), and a home made rear lift with spring assist.
Old 04-25-2011, 08:51 AM
Sweet find! The tins look to be in pretty good shape! I wonder how many PO mods your going to find. It's still worth saving tho! Thanks for the pics!
Old 04-25-2011, 11:39 AM
Nice find on the 800! You have a very rare tractor!
Old 04-26-2011, 12:14 PM
jmroy's Avatar
Thanks guys, the tractor is definitely rough. The upper grill is cracked pretty badly, the PO put some sort of brace on it. The dash is also cracked pretty badly. It seems most of the tins around the motor are cracked around where the bolts go. This is my first wide frame tractor so it should be an interesting experience.
