Old 04-24-2011, 07:56 PM
Nick2225 Nick2225 is offline
Default tires for 1200
hello kinda new to this site. I have a 1200 garden tractor it has I guess you would saw stock narrow tires on the rear, and I was wondering if anyone could tell me what size i could put on it, to make the stance of the tractor a little more wider, and for better traction as I cant hardly go anywhere in my yard without getting stuck. thank you for any help
Old 04-24-2011, 08:31 PM
Being it is a 1200 I am going to say you may have 23X8.50X12 tires. You can put a set of 23x10.50x12 ag tires on and have a wider stance and much better traction. No they don't tear up the yard. Or at least mine don't. They will fit the narrow rim, but would be much better on a set of factory 8.5" rims instead of the 7" rims.
Here is a chart to help you out:
http://www.onlycubcadets.net/forum/showthread.php?t=477
Old 04-25-2011, 09:36 AM
Are you spinning your tires alot? Are you using any wheel weights? I assume your using turf tires now?
Old 04-25-2011, 11:52 AM
Wheel weights will help a bunch, and you don't have to use factory cast iron ones if you cannot find them. Folks have used round concrete weights with bolts cast in to match the wheel holes for the weights , not hard to make and not too expensive. Just need a round form.
