After spending the weekend at my grand parents place i took some pics of his cubs. Im have trouble trying to find out when it was made. I did find the number stamped on the rear end, and the spendles look different than those ive seen with other members. Its all original (no pun intended
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
That isn't the serial number. The number is on the right side of the casting between the frame and rear end. Seeing the front spindles and no hole in the frame for a creeper it's probably in the first half of 1961 production though. There's a good chance it's a 4 digit serial number too (doesn't have to be though).
Preserving history... one Cub at a time. |
![]() Quote:
I'd say no to a prototype because I think I remember the prototypes having subtle changes here and there that were made before production. I don't remember what they all were. As for the air breather, repainted maybe? From a different brand that used the same breather? Now there is a slim chance you've run into a 3 digit Original? I'm just speculating things now. Even a prototype would have a serial number though.
I don't see a creeper hole so that makes it a early 61. The foot rest do they have holes in them? If they are flat without any holes it's not a protype O. I have no clue why the oil bath is blue. Kevin would know more about it then I would. No matter which version of O it looks to be a great looking tractor. Any chance you'll end up with it?
Nice find. Love the barn finds. The serial would be stamped on the right side. Early front axle and collared spindles. No creeper hole. Blue air cleaner was probably a PO repaint or from something else. What was the engine serial number. If it was a prototype, the engine may have a prototype serial number unless it was replaced.
Duke, Correct me if I'm wrong but didn't the production O's have footrests with holes stamped in them? Paul Bell owned a prototype, serial number 409 and the foot rests were smooth. They changed them to stamped holes to improve traction when your feet were wet. Foot slippage would hurt, especially with the shifter where it is, OUCH! ![]()
Josh Diesel Cub Cadets........... |
![]() Quote:
Early '61's had collars on the spindles and no holes in the foot rests, such as yours does. Also they did not have the access slot in the tower for the steering adjustment screw (right side). Now depending on who you talk to when they switched to the holed foot rests, and bolted spindles varies and also some 4 digit tractors do have the bolts due to replacement of worn parts. Also the prototypes had an hour meter installed on the lower part of the pedistal on one side.
Jay N. Eau Claire, WI RED 82 Series... The BEST cure for Yellow fever! ![]() |
This is mine an early 4 digit with the collard spindle's. You have to look close but their hiding under there
2013 cub cadet GTX 2100 w/IH weights 1984 cub cadet 1282 w/#2 cart, plow, IH weights 1970 IH cub cadet 73 w/fenders Haban 402d sickle bar 1966 IH cub cadet 102x2 1966 IH cub cadet 71 pull start w/Fenders IH sweeper, Brinly Gard N Cart 1965 IH cub cadet 100 w/Fenders hydro lift Brinly Gard N Cart, 3 point sleeve hitch Brinly plow sleeve hitch blade #1 cart 1965 IH cub cadet 70 w/fenders and snow plow 1961 IH Cub Cadet Original #3646 w/fenders 3 point, IH rear blade, non trip snow plow |
Hey, my 784 has a blankie just like that, LOL.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
