While painting the lift lever for my 124 I managed to drop the entire assemble and it broke the "thumb button" off of the top. It looks as if the thumb button was threaded in with a 3/16" bolt that was integral with the button. It broke off cleanly down in the shaft, and I have about 1/4" of threads left on the button. I'm thinking that the best way to fix this would be to drill out the portion still in the shaft, and re-thread it for a replacement button or a stack of washers and a replacment bolt to act as a button. Has anyone else had to do this? Any words of wisdom or alternate ideas? I need to get this fixed asap, and I am not concerned about the appearance/"authenticity" of the fix.
Thanks. |
You're not having any luck with your ?. I have the same problem on a green tractor that I bought from a neighbor, and was wondering if there was a quick fix for it. I'm going to work on it today to see if there's anything I can do. Good Luck. I have to get rid of this tractor to make room for 2 more cubs that are coming my way on friday.
147 w/mower deck, plow and rototiller owned for 22 years 149 new to me in 2010 2 more 149's with a a42a snowblower new to me in 2011 |
the button on my green tractor ended up being a round piece of metal with a 1/4-20 thread in it, and it screwed onto a shaft inside the lift handle. Only cost 3 bucks
I have seen some with wooden dowels stuck in them,they worked but there is no float.
Did you have any luck fixing your issue? I don't know how you would go about it, but if worse comes to worse, see the for sale section (125 parts MO), my tractor that I am parting should have the parts you need to get you going. Good luck getting it fixed!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
