Today, I pulled the cover off the deck pulleys to inspect the belt, and noticed how loose the deck belt tensioner was. I got to looking and noticed that the shoulder bolt was completely seized up in the tensioner arm (must be why the new replacement bolts have a grease fitting
![]() From the pictures, do you guys think I should have a plate welded on there to fix the oblong hole, or will it be ok to go ahead and bolt it in place? Should I also put a new spring on? Is this a common problem? Any other advice? Thanks for the help. '85 1210 w/ 44C deck. |
well it wouldn't be a bad idea to weld a plate there but you might get away with puting a flat washer between nut and bottom of deck. if you weld it use low setting as posible so you don't burn through.
