Old 09-06-2016, 04:05 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
I don't recall what size it is. There is supposed to be a plastic sleeve on the shaft. If yours is gone, that explains why it is tightened down with the ends touching.
After I looked through the parts diagram I noticed a bushing should be there. My guess is it's gone, I'm hoping to get it apart soon and find out.
Originally Posted by JLM78 View Post
The newer 149s had the nut on the bottom They did A up grade
That's what I noticed. I'm trying to deal on a 1250 parts tractor. Could I swap the lever assembly from a 1250 into my 149?
The guy wants $100 for a 1250 w no engine or sidepanels and a handful of other odds and ends (wheels, battery tray, air filter etc) I think that's a little high, trying to get him down to $75.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 09-06-2016, 04:27 PM
JLM78 JLM78 is offline
your have to use the dash/tower off the 1250
Old 09-11-2016, 02:17 PM
vr4Legacy's Avatar
I got the adjustment bolt out and removed the clip on the bottom of the speed control rod. I used a 11/32 socket and 1/8 allen wrench. Gonna get a new bolt and lock nut.
There was a bushing in there, but it's quite worn. I'm going to see if I can find something at a hardware store to replace it, the part is $7+ shipping. Looks like any 1/2"ID x 3/8" plastic bushing should work.
-Jason
Old 09-16-2016, 06:31 PM
vr4Legacy's Avatar
I looked and looked and couldn't find anything readily available to replace the bushing. I thought bushings for a toro axle might work, but I stopped at my local toro dealer and checked them out, too small.
I finally decided to use my WV ingenuity, and wrapped the bushing with electrical tape once around. It added just enough thickness so that I could tighten it down.
I drove the tractor a little bit this evening and the lever works much better. I just adjusted it by guessing on the tightness. The manual says 7-12 lbs of pull force to keep handle in motion.
It still seems to want to take off if I push the speed control above halfway and let go. But I didn't drive it much, so I can't really say. Perhaps I need to adjust the lever a little tighter?
I also need to adjust the brakes more. They don't do much right now. Trying to figure out the best option. They have a little pad left, but I am bottoming out on the adjusting nut. I hate to just keep adding spacers/washers to the rods. I think I may try to put something in front of the arm on the brake pads itself, adding a little thickness.
All in all though, I think it's ready to test out. I probably won't get a chance for a couple weeks.
-Jason
Old 09-16-2016, 08:33 PM
Cub cadet warehouse has the bushing 7.50 but 10.00 shipping sucks
Old 09-17-2016, 05:57 AM
twoton twoton is offline
http://www.onlycubcadets.net/forum/s...=8138#post8138
Old 09-17-2016, 07:43 PM
vr4Legacy's Avatar
Yup. I found them a couple places online. Local cub dealer says they're NLA, so NOS is all that's available.
That's why I used electrical tape lol. If I ever place an order I'll throw one in, but I can't justify the shipping.
-Jason
Old 09-17-2016, 07:49 PM
vr4Legacy's Avatar
Originally Posted by twoton View Post
Thanks!
I doubt I'll get to it this year, but I certainly plan on relining them. There's enough pad left to last for my needs over the next year. Especially considering it's a hydro.
-Jason
Old 10-14-2016, 08:46 PM
vr4Legacy's Avatar
I finally took the 149 out and put it to use. I swapped the seat off my 1200 and pulled a cart around to pick up sticks and fallen limbs I've pilled up throughout the summer. The speed control seemed jerky, I had to give it a lot to get going up hills, then back off once it was moving.
For now I packed it up with the 1200 for the winter. I'm going to keep an eye out for a WF subframe for my push blade. But for now, I'm done wrenching on the Cubs for the season. I plan on pulling the driveline off the 1200 in the spring and getting it straightened out.
<I keep getting errors uploading pics, I'll come back later with a few for your enjoyment >
-Jason
