| View Poll Results: What color should the wheels be? | |||
| White Wheels |
36 | 81.82% |
| Red Wheels |
8 | 18.18% |
| Voters: 44. You may not vote on this poll | |||
#51
My vote is red, great job so far!
1971 IHC Cub cadet 106 1982 IHC Cub Cadet 682 (looking for engine) |
#52
It's either full factory or full custom for me, no in between.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains |
#54
Someone please tell me what I am missing here!
When I took the steering wheel off, this is all that was on the top end of the column. Seems like there should be some type of retainer to go up against that white bushing... or maybe the last guy put it together wrong? IMG_0795.jpg IMG_0797.jpg |
#55
There is a foam insert that goes in there, in between white piece and steering wheel. Some guys use a front wheel bearing in place of what you have, converts 2 piece into one piece bushing which also works but some gnurling needs to happen or some put in small amount of foil around bearing OD to keep it from working its way out. CC makes a plastic bushing that replaces the OE style sleeve and insert like you have. Looks up Parts breakdown and you will see.
#56
ahh ok thanks.
so you are saying I can remove the plastic piece and metal seat it rides on and install a front wheel bearing with some slight modification? that sounds like a good way to go |
#57
https://youtu.be/--a0RYK65Yg
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
#58
great vid, thanks
#59
![]() I like the original look/color. That's my "opinion", and I'm stickin to it. ![]() As Jeff wrote, "You have to look at it, pick what you want."
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#60
Big thanks to Kelly for the WF front axle for the 122!!
More pics of the project coming soon.
