#41
#42
It has Kohler MPN's of 47 010 06, J-235675, and 47 010 06-S. Will this work in any Kohler K241?
![]() ![]() ![]() ![]() 1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106 |
#43
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
#44
I'll probably get that one, then it's out to the barn when it comes in.I'll be putting this thread to bed for awhile.
#45
My parts catalog for my 102 says that the PN for the 102's K241a camshaft is 47-010-09. Perhaps 47-010-06 is identical? I'm not sure.
#46
![]() Then again, it wasn't real high dollar...
#47
There's a decent chance the bore has gone egg-shaped, have a machine shop take some measurements if you aren't sure how.
One other thing, pull the governor gear and cross-shaft out while you're at it. The cross-shaft has a metal tab that is pop riveted on and they tend to break off at this age. Mine fell apart in my hands when I pulled it out. Looks like the replacements available are now welded. |
#48
#49
![]() Regardless, I looked up the 2 camshaft part numbers and there doesn't seem to be any difference between the 2... perhaps Kohler changed the part number for the camshaft somewhere in the production run?
#50
Test....metal
