Old 01-19-2015, 07:36 PM
steved steved is offline
J-Mech, thanks for the response. Yes, the reed was removed for the picture. Tomorrow I'll use a small wire and check the drain hole. Should I replace the two gaskets since they probably have oil on them? If the drain hole was plugged, do you think that might be my problem? Thanks again.
Old 01-19-2015, 07:47 PM
Merk Merk is offline
Basically shouldn't hold oil in there at all.
Two question:
~Where is the reed valve? Was it just removed in the pic?
~Is the drain hole in the block clear? Make sure it isn't obstructed.
As a note: I use adhesive to "glue" the gaskets on to the back of the inner cover, and on the back of the outer cover. NO SILICONE. I use weatherstrip adhesive. Those gaskets CANNOT get oil on them before installation. Make sure everything is dry, or they will leak. Once compressed, they are fine.
Is the drain back on the bottom side?
Project Uncle Dick
Cub Cadet 70
Old 01-19-2015, 07:50 PM
Yes, the drain hole is in the bottom of the breather plate.
Old 01-20-2015, 03:11 PM
J-Mech, the drain hole is clear. The gaskets that leaked were Kohler parts. I cut two more out of gasket material and am going to install this afternoon. Maybe I did not tighten down the cover plate enough. I was worried about collapsing the cover.
Old 01-20-2015, 03:44 PM
Ok. Yeah, tighten it down. You can't get stupid, but it needs to be pretty tight.
Old 01-22-2015, 12:58 PM
RLemke's Avatar
RLemke RLemke is offline
i believe the decal is meant to replace the tin not be put on it, as someone whos done a lot of sign work i can tell you that putting decals on a textured surface is a short live thing as air and dirt get in behind it it will start to come off.
Huh? Are you saying that the decal is meant to go directly on the fiberglass dash housing instead of the tin dash plate? That would suprise me. It looks like there was originally a decal on the tin, which is probably why most of them fade and wear off after 30+ years. Have you ever seen one applied directly to the dash without the tin?
Old 01-22-2015, 01:52 PM
The original tins are painted not decals, yes I've seen a few at shows that have the decal directly on the fiberglass. The fact is that decals do not like to stick to rough textures very well especially ones printed on chrome vinyl since its a lot less forgiving .
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-23-2015, 04:43 PM
I wish you had chimed in earlier when I was asking about the decal and tin. I know I'm not the only one doing a project like this for the first time. I'm working through each problem one at a time. Asking dumb questions and learning as I go. If the decal doesn't last, so be it. This machine will not be parked outside as long as I have it. This project started as a need around the yard and also kind of reconnecting with my Grandfather. I thought about applying the decal directly to the dash but that seemed kind of hokey. You know, decals on toy cars. I thought the 3d look with the embossing and cross hatch would look good and it does. I was going to punch a new dash tin out of sheet aluminum(CNC punch,in fact even drew it up) to give a little raised appearance but decided even that would not look good. If it doesn't last I can always go back and do it another way. At least I know how to take it apart now! Thanks again to everyone that's helped on this fun project. I need to get it done so I can start on the tiller before spring!
Old 01-23-2015, 05:19 PM
sawdustdad's Avatar
Steved, don't fret over putting the decal on the dash tin. I looks great. I would have done the same thing because putting the decal directly on the dash would have looked odd. Another option, not for the faint of wallet, though, is to find a NOS dash tin. I've used a couple. Makes the restoration if you are going for a real original look. I wouldn't go to that expense for a worker, though.
You are doing a great job. Can't wait for the final pics!
Old 01-24-2015, 02:13 PM
I'm having a fit getting all the linkages re-set on this engine after pulling it for the second time to fix a leak. I decided to start over at the very beginning and clean and reset the carb. The float level was a little off the 11/64", not much. Going through the manual very carefully, I noticed I had not set the float drop. The manual calls for bending a tab. My float does not have a tab. Does this matter? Thanks for everyone's help!
