Old 02-02-2013, 08:55 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Originally Posted by cnixon View Post
Most of the time I have found that the spindle get stuck in axle making it not steer. I would try that first.
VERY true...I bet this is it... made an enormous difference in my "woods fresh" O
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 02-02-2013, 10:35 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Okay, tomorrow will be the test day for the engine. I got it all wired up tonight.
Couple things, is there a way to repair the head for the spark plug, it is stripped out from sitting there 25 years, it just deteriorated when I took it out.
Also, do they make a smaller coil for the 7HP's engines? There is no way in heck I am going to get the bracket in both holes in the engine shroud and put the coil in it, It just isn't happening. Maybe there is a smaller bracket maybe?
- Cory Sanderson
Old 02-03-2013, 06:03 AM
Cory
You should be able to pick up a spark plug thread repair kit at an auto parts store. They are similar to a heli-coil.
Old 02-03-2013, 09:53 AM
cubfixer's Avatar
cubfixer cubfixer is offline
I have a smaller coil for my 100 than my 125. I could never figure out why the bracket didn't fit the holes. Smaller coil fixed it. For a while, I ran with just one bolt into the shroud, and put a longer tightener bolt across the coil bracket holes (that pretty plain, huh? )
John
Old 02-03-2013, 02:34 PM
ihcc104's Avatar
Well, I cant seem to get it to run. I am not sure why, I have spark at the points and the spark plug, and I shot 1 squirt into the carb with Starting fluid, but no luck. She will not fire. I am not sure why however....
Cory
I will have to check into that. Thanks!
I would like to try to find a smaller coil. I have the 1 bolt in it now and it is working for the time being, but not for long term..
- Cory Sanderson
Old 02-03-2013, 03:47 PM
I use an empty gear oil bottle with a pin size hole in the tip to squirt some gas into the carb throat to get them going. I hate using starting fluid.
Old 02-03-2013, 04:07 PM
cnixon's Avatar
cnixon cnixon is offline
Did you put your thumb over the spark hole to see if it had any compression.
Old 02-03-2013, 04:20 PM
ihcc104's Avatar
I know you do buddy, I remembered what you said and only did 1 squirt; dont want it to end up like that engine you showed me..
It seems like it has compression, it is hard turning over by hand I know that.
- Cory Sanderson
Old 02-03-2013, 04:43 PM
Did you do a compression test with a gage? Is the timing in the ball park?
Old 02-03-2013, 04:47 PM
cnixon's Avatar
It may turn hard with pulleys and clutch having 25 years of rust. With spark and gas and no go I'm thinking compression.
