Old 03-24-2011, 10:23 PM
Awesome pics, Adam!
Old 03-26-2011, 08:02 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Adam,
What is the large piece of black square tubing mounted above your hitch? I'm assuming its a weight of some sort.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 03-26-2011, 08:19 PM
cub123's Avatar
cub123 cub123 is offline
I think it is the oil tank for his custom hydraulics maybe?
Old 03-27-2011, 02:29 PM
IHinIN IHinIN is offline
Originally Posted by litlmikeyl View Post
Adam,
It is a weight bar. It's a piece of 4" x 1/4" wall tubing filled with 5/8" all-thread. It weighs 63 lbs.
Old 03-27-2011, 02:33 PM
The reservoir is built into the pump.
Old 08-20-2011, 06:43 PM
I made some improvements to my subsoiler to make it work better. I first angled the shank forward to help it pull itself into the ground so I don't have to use down pressure to get it in the ground. That helped but it still wouldn't go more than about 6-8" deep. Then, I added a weight bracket on the back to hold two 2 gallon jugs filled with sand. That added about 50 lbs and now the subsoiler goes in the ground easily without having to use down pressure. It seems to go deeper into ground that hasn't been worked recently. In the pics I was using it in the garden where I had tilled between the rows of sweet corn and it's about 9-10" deep. I tried it along the edge where it hadn't been tilled and it went 12-13" deep. I was amazed that it didn't spin the tires. Those old Sears tires aren't so bad after all.
Old 08-20-2011, 07:00 PM
Top notch work, as always, Adam!
Old 08-20-2011, 07:02 PM
Thanks Allen.
Old 08-20-2011, 07:05 PM
Your work is impressive. I like that sub soiler
Old 08-20-2011, 08:53 PM
Glad to see you are getting it perfected
Nice fab work
