Old 02-25-2011, 09:49 PM
IHinIN IHinIN is offline
Default Subsoiler attachment
I'm going to build a subsoiler for my 100. The other day, my friend and I got to talking gardens and he was saying how he wanted to be able to work his ground deeper and I got the idea of building a subsoiler. My plan is to make it with a single shank that will go about 12" deep. It will mount to my sleeve hitch adapter and use a cylinder to give it more travel since the 3-point doesn't have enough travel.
Old 02-26-2011, 12:08 AM
Adam looking forward to your progress. I'm sure like everything else you do this is going to be top notch.
Old 02-26-2011, 12:44 AM
nickvanorman
Guest
Posts: n/a
a Subsoiler is going to be a little much for a cub i would think. i mean, if your only going 12 inches that should be okay. depends on how deep your hardpan is. i know sometimes a 175hp 4wd John Deere tractor has trouble pulling a 3 shank subsoiler in the ground around here running about 15inches deep.
looking forward to seeing what you come up with!
Old 02-26-2011, 09:24 AM
cub123's Avatar
cub123 cub123 is offline
I have a Subsoiler that i made for my sears and it had no issues pulling it at about 10-12 inches,i cant wait to see pictures of how yours comes out!
Old 02-26-2011, 12:51 PM
IHinIN
Not trying to talk you out of building your own but i thought this was a good idea. If you own a plow, Tractor supply has the replacement ripper shanks for a box blade and they already have the holes in the right location.This is what a guy on another forum did and said it worked great.
I am going to try it and see how it works.
Old 02-26-2011, 02:26 PM
ihnick's Avatar
ihnick ihnick is offline
so does a sub soiler do the same as what a chissel plow would do behind a farm tractor?
Nick.
Old 02-26-2011, 03:26 PM
Diz,
That's a good idea but I don't think that would go any deeper than 8" or so. I'm building mine to go 12".
I made a little progress today. I used some plywood to mock up the shank and the cylinder in the retracted position.
Old 02-26-2011, 03:37 PM
mrcubcadet's Avatar
That will be very cool! Can't wait to see more pics
-105___ Tiller
Old 02-26-2011, 05:47 PM
Looks very neat, Adam! Can't wait to see your future updates!
Old 02-27-2011, 07:53 PM
Today, I got the pieces made for the front cylinder mount. I'll get it welded tomorrow and start on the rear mount and the shank. It should all be done this week.
