#21
![]() Quote:
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
#22
Sorry no updates. Too many other projects and multiple late nights at work.
Hopefully back onto hitches this weekend!
1512 with CADloader 507, CADdigger 508 and 3 pt 1711 with KT17 782 with KT17 and 3 pt 104 |
#23
Both hitches welded up. The tombstone did a pretty good job welding. Welds aren’t that pretty but they apprear strong and had good penetration.
Access hole for linkage pin drilled. A6D59BAC-B08C-4FA7-90BC-D56D60E24D0D.jpg 55352AED-9086-45D0-BC9E-ECB32B23F8ED.jpg
#24
#25
#26
Small steps every day!
63B03770-2CD7-4B75-A7A2-370510F747E2.jpg Finished the second top link bracket. Welding getting better with tombstone. 0B3B92E4-8EE5-4A02-B960-28BAA4C2E2A7.jpg Adjuster parts before grinding and welding. 65318CEB-77F7-4A32-BAFA-97C8EC0C7988.jpg Adjusters for rear lift arms. 61F2530D-8B7E-440E-9019-650314B8FB0A.jpg Adjusters on threaded lift arms.
#27
#28
Do you have a pattern for the lift rod? I have a new 1 I'd like to sell. It's from my 1864, it was used twice and then I modified the 3pt.
#29
Few more step!
A77BAC64-D1B8-4F25-969E-41A03F029280.jpg 1st coat of paint. Thanks on the lift rod but I have one from my 1512 build which I used as a template.
#30
Well it has been a while but 1st install and test is complete!
27644004-351A-43E2-9A8B-E3A744E08320.jpg I put the 3 pt onto the 782i rebuilt. Made a few passes on the driveway with the grader blade. All seemed good!
