Greg Rozar AKA- CubDieselFan
Old 08-17-2017, 06:40 PM
Workinprogress Workinprogress is offline
Default 3 point hitch build
Yesterday was a busy day in Cub Land. Was able to cut most parts out and drilled many to build 2, 3 point hitches. One for my 1711 and the other for my 782/4.
Another 15-20 holes to drill tonight.
Then onto welding!
1512 with CADloader 507, CADdigger 508 and 3 pt
1711 with KT17
782 with KT17 and 3 pt
104
Old 08-17-2017, 09:43 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Keep the pictures coming and did you make the lift bar.
Old 08-18-2017, 06:01 AM
Yes I made the lift bar. I made the hitch from my 1512. That took a lot of adjustment/ bend/ test fit. This time I just copied the bar that was working in my 1512.
1711 with KT17
104
Old 08-28-2017, 09:40 PM
Everything drilled. Started welding parts up.
Completed one side of the lift arms. Took some time to build a jig to have the correct spacing and alignment. Then welded some washers onto the side plates. Progress ended when I ran out of welding wire.
1711 with KT17
104
Old 08-28-2017, 10:06 PM
john hall's Avatar
Looking good so far, keep the pics coming!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-28-2017, 10:15 PM
What kind of welder are you using? Are you running flux core wire?
Old 08-29-2017, 11:12 AM
I am running a lincolin weld-pak 100 (120 volt) wire feed welder with flux core wire.
1711 with KT17
104
Old 08-29-2017, 04:38 PM
Spent some time welding today. Top picture is with the plates tacked together.
Lower picture has plates welded together right before i welded outer arms on. The outer arms are now welded but I still have to weld inner arms on. Ran out of time. Had to load the 1512 and York rake up so I can rake out the little league inner field tonight. More time on the Cub!
1711 with KT17
104
Old 08-29-2017, 07:01 PM
DieselDoctor's Avatar
Looking good!
Old 08-29-2017, 07:11 PM
Hey...... before you spend a bunch of time, a flux core wire isn't going to penetrate deep enough to be able to hold the lift lever (crank arm) to that rockshaft. You will break the weld. Your welder isn't large enough. Sorry man.... it's just not going to hold. Oh, it may for a while, but it will break.
