Old 08-01-2016, 01:06 AM
Zipper Zipper is offline
Default Getting 1250 back into good condition
Started getting the 1250 back into a good working order today. Got her into my small shop and pulled the engine. I had 2 bolts missing from the right side of the oil pan. Other than that, nothing else was much of a surprise. Going to do the cradle mod and see the condition of the pan to determine what is needed next. Going to go with solid mounts. I think the driveshaft couplers are due. I have grease oozing out of the steering box. What do I need to get it back into good shape? It has a bit of play in it but nothing ii would consider excessive. I don't feel any play in the axle pivot. I think I may need a new head gasket or is this normal for a 40 year old Kohler?
Old 08-01-2016, 01:08 AM
One more question.
I thought ii read somewhere that if the dipstick iis on top of the Kohler then it doesn't have balance gears. Can someone confirm this?
Old 08-01-2016, 07:34 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Originally Posted by Zipper View Post
One more question.
The quiet line engines did not have balance gears
1- 1200 in pieces
1- 1864 in pieces
Old 08-01-2016, 08:25 AM
mortten mortten is offline
I'd replace that head gasket and flatten the head.
Old 08-01-2016, 11:32 AM
That is normal for a 40 yr old Kohler that has a warped head and in need of a gasket. Be sure to sand the head flat on a piece of glass before reinstalling it.
No balance gears in that engine.
Gotta take the steering gear apart and inspect the pieces, be sure to consult a good exploded view of the the steering gear and inspect the cups closely.
Old 08-01-2016, 01:07 PM
Thanks everyone for the great advice. Please mention anything else that should be done while I am at this stage!
Old 08-06-2016, 10:26 AM
nix1650's Avatar
nix1650 nix1650 is offline
the 301 aqs engine HAS balance gears. all the QL engines I have rebuilt have had them in but are removed in the rebuild
Old 08-06-2016, 07:17 PM
Took head off engine. I think the piston looks good!!! Let's see if anyone else disagrees.
Thanks TwoTon! I love having all the links in this thread. Super helpful for anyone searching! Your a great asset to the site. Read through your long, long thread the other night. Picked up a bit here and there from it. It shows how fast someone can go from a mild fix to a complete restoration!
OK, this sucks! I have 1 vote that it has balance gears and 1 that says it doesn't... UUGGRRHHGG!!! Which is it? Let me add serial number. 7425521. K301AQS. Spec 47581d
The pan does had a very minor amount of contact at the cradle points but I couldn't tell a difference in it from the side that still had the bolts. Only it was shiny. I think this may have been the perfect time to pull the engine and address the cradle.
Old 08-06-2016, 08:40 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Good luck with the repairs. Certainly a wealth of knowledge on this site.
Here is a link to the manual for the K301 engine
Owners
http://www.kohlerengines.com/onlinec...1346_c_all.pdf
Service
http://www.kohlerengines.com/onlinec...df/tp_2379.pdf
Perhaps it can help figuring out if there are balance gears.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 08-19-2016, 08:07 AM
johncub7172's Avatar
Correct. The k321aqs in my 1450 had them until I removed them. My first 1450 did not have balance gears. But to say the Quiet Line aqs engines never came with balance gears is a very false statement.
