#21
![]() Quote:
And nice looking tractor. ![]()
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus ![]() |
#22
Update:I think I got taken advantage of on this thing, I guess that is what happens when you trust someone you know.
PTO is fried no way around it. the coil? (outside part) is bent partly causing a slight metal on metal noise when a it is in free wheel. the field? magnet is destroyed! it has gotten very hot again was told it worked last year ![]() I did not ohm this part due to how it looks. See Picture the muffler was cracked and a piece of plumbing pipe was shoved over the spout and a hose clamp in attempts to tighten it up I may try to re weld the muffler see Picture the plate that the muffler bolts to is broken in a few spots top and bottom so it rattles I do not know if I can find a new one or not to replace this it is a pot metal so repair is a no-go there is also a bolt that holds that plate in place that goes on a cylinder, the bolt is broken off inside the assy I do not know if it would be worth trying to fish it out. everything is covered in oil for a engine that has less than 20 hours on rebuild. I am very upset at myself that I did not pick this thing over better before I bought it. Now I get to throw some money at this and hope the wife does not find out ![]() |
#23
Muffler is a common issue on these. I had my muffler bracket welded for $35 and bought a used muffler off ePay for $30. PTOs are usually pricey though.
#24
well maybe just maybe it can get welded but I am missing some parts where the muffler bolts to it. I wonder If I could make a new one out of metal?
#25
![]() Quote:
As a suggestion, I'd look at these guys for a new PTO. Cheaper to replace the whole thing than to repair the old. Even used is close to this price. http://xtremeope.com/ I can't find the PTO on their site, but here it is on Evil Pay: http://www.ebay.com/itm/PTO-Clutch-F...0AAOSw14xWNVPD |
#26
What makes you think the field coil is shot? Because of the cracking in the covering? The metal you are hearing in free wheeling is possibly just the brake drum rubbing on the rotor and armature. And that's normal.
I'd still check it out to make for certain it's bad before dumping the money into a new one. The other issues you have going on are typical with the QL muffler box and muffler. Make a crutch, and patch up what you can. It can be done, been there, done that... Or, step up and buy new. Your tractor, your money. BTW, don't look like a fresh 20 hr rebuild to me.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
#27
I'm with zippy, check the pto out. What's it gonna hurt to check. Then you'll know if it no good. If it's no good then buy one. Mine is cracked like yours and works fine for being 37 years young!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
#28
As others have said, check the PTO coil out, I've seen worse and work fine.
I have used epoxy to coat the field wires to replace the cracked insulation with good success. Don't be disheartened we all have BTDT. when it is all said & done you will have a nice Gt and it will still outlast the newer throwaway's ![]() And you will feel the warmth of being to able to say I fixed it, and gave it new life. |
#29
Lesson to Ol'George, he's an old fart who like to fix things were others quit trying!
![]() I'm kidding but you know what they say...Their is always some truth in a joke! ![]()
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
#30
Clutch is junk no contanuity between the coil found a bare wire at the back side also where the coating was worn off and maybe it grounded on the case
