#21
You may want to check the bearing behind that front shaft seal, it the shaft moves very much, you'll want to replace that bearing also.
#23
Thanks Sam...very little (if any) play on that shaft. The front coupling got removed much faster than I thought it would (the "cousin" on the drive shaft took a lot longer). Dropped the front coupling piece into a tub of kerosene and the liquid went black! Noticed that there is a very pronounced groove near the rear end of the casting which I guess is for grease that stays there until the next guy tears it apart 40 years from now...can't think of any part of the connecting parts that would cut a channel like that. Looking at trunion repair now...mine looks like several pieces shown in the pix...overall pretty square other than the "grooves". I don't have a welder but guess I'll figure something out.
#24
Stop by your local Mom and Pop body shop with it one evening a little before quitting time, one of the guys there will weld it up for you for a six-pack. It won't take them 30 seconds to do the work.
Then take it home and file the corners back square again.
#25
Long wanted to re-learn welding...this might be the excuse to buy a welder! Some pix of what I am working on as I decide whether to keep going or part this out...you can see the typical groove on the trunion plate...so move to the yellow part and tell me whether that is normal wear and whether it will matter. The shoulders seem to have some unusual wear. Looking at the trunnion shaft in the hi-def pix I now see some grooves that I don't see looking at it on the bench. Guessing there were shims on that to hold the plate tighter to the pump so as to avoid all the excessive wear but think they bailed out long ago...The linkage plates/rods (not shown) all appear to be in great shape. Will be heading to see Harvey tomorrow with my parts list...he is new Cub stuff but I know he has a "bone-yard" out back.
