Old 09-30-2014, 09:28 AM
Nick
This is what the bearing should look like. You'll see it fits flush with the end of the shaft.
Old 09-30-2014, 11:01 AM
thanks sam, mine will not go on flush, and there isnt much more room the basket pulley can go back, i dont think it ever went on flush.
Old 09-30-2014, 11:03 AM
The brass button is a press fit just like the fiber button. Nick must have added the nut.
mine has a threaded end, no press fit, thats why its on there, i wonder if it would stay in without the nut?
Old 09-30-2014, 11:28 AM
Never seen one that was threaded. Who did you buy it from?
Old 09-30-2014, 11:54 AM
A guy who lew knows who works in a machine shop.
Old 09-30-2014, 11:57 AM
I've seen a few that were threaded, seems like a good idea if the hole in the arm is a little messed up and a press in button won't work.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-30-2014, 12:43 PM
I'm going to say this only because it hasn't been mentioned yet and because no matter how much mechanical work we do we can all make mistakes or overlook things.
If you haven't done it already, check to see if the locking collar for the bearing is positioned on the back of the bearing inner race in the unlocked position yet all the way up so that it is as close to the back of the bearing as possible. If the locking collar is turned the wrong way and not setting on the shoulder of the inner race it could be holding the bearing out a good little bit.
Old 09-30-2014, 02:53 PM
Guys, I think I fixed it, I got the pto on a lot further by lining up the set screw holes with the basket pulley slots, I also got the bearing on flush by using the original locking collar, although that probably doesn't have anything to do with it.
Old 09-30-2014, 04:02 PM
Do the long pto set screws go in first?
Old 09-30-2014, 04:05 PM
Sure do.
Pap's 100
Restored 108
1211 Dual Stick
1050
