Thread Tools
Display Modes
#21
That's why a lot of old ford tractors were converted from 6v to 12v, the engines were to wore out to start on 6v so they convert them to 12v so it builds compression faster.
#22
A stuck exhaust valve that sticks due to heat usually unsticks the INSTANT the engine quits, so the symptom is not seen when cranking the starter.
On my 149, simply reducing the forward speed while plowing snow, just a little, was enough to reduce the problem so that the machine would then begin to have full power. The spring that is trying to close the valve is VERY powerful, it does not take much to change the symptom,,,, |
#23
![]() Quote:
Most of the time you can pull the valve, clean it and the guide well with a brass brush. Problem solved! ![]() On the 6V-12V conversion thing, RIGHT ON, Tim! ![]() |
#24
Exactly! Clean that sucker and get back to using it! I still hold to using Low Ash oil to prevent it from happening. I tried it, and it hasn't happened since. I read an article about it in Red Power a long time ago on the Yellow and White section.
Restored 1970 127 1962 Original |
#25
Sorry to hear about the cub issues. Sometimes when it rains it pours. Keep trying, you'll get it going in the right direction.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
