Old 09-08-2014, 11:02 AM
NOTE: It takes more compression to start a motor, than it does to run one. If you can get them started, they will run with pretty low compression. Not well, but a motor will run.
That's why a lot of old ford tractors were converted from 6v to 12v, the engines were to wore out to start on 6v so they convert them to 12v so it builds compression faster.
Old 09-08-2014, 11:26 AM
A stuck exhaust valve that sticks due to heat usually unsticks the INSTANT the engine quits, so the symptom is not seen when cranking the starter.
On my 149, simply reducing the forward speed while plowing snow, just a little, was enough to reduce the problem so that the machine would then begin to have full power.
The spring that is trying to close the valve is VERY powerful, it does not take much to change the symptom,,,,
Old 09-08-2014, 11:35 AM
I agree!
Most of the time you can pull the valve, clean it and the guide well with a brass brush. Problem solved!
On the 6V-12V conversion thing, RIGHT ON, Tim!
Old 09-08-2014, 05:49 PM
HoundDog's Avatar
HoundDog HoundDog is offline
I agree!
Exactly! Clean that sucker and get back to using it! I still hold to using Low Ash oil to prevent it from happening. I tried it, and it hasn't happened since. I read an article about it in Red Power a long time ago on the Yellow and White section.
Restored 1970 127
1962 Original
Old 09-08-2014, 07:48 PM
Sorry to hear about the cub issues. Sometimes when it rains it pours. Keep trying, you'll get it going in the right direction.
