Old 09-11-2009, 07:20 PM
cub14501650 cub14501650 is offline
Matt...Thanks for the info,I finnally got to actually getting dirty and taking the pannel off the bottom of the frame and upon further inspection I have a leak in my oil pan(Thanks!).It was really deceiving to actually tell where the leak was comming from because the oil was leaking on the mount for the mower deck and the belt was indeed picking up oil from the flat brace on the deck and throwing it up around the PTO and the front of the engine.I called around and found a used pan and mounts pretty cheap,as long as these weren't leaking do you think used is an ok idea?
Old 09-11-2009, 09:25 PM
Get new mounts or you'll probably be in there again. I'd add the cross brace between the framerails, as well.
Old 09-12-2009, 08:04 AM
MBounds's Avatar
MBounds MBounds is offline
Uuuuhhhh Matt: "Between the frame rails"??? Don't 'cha mean "between the Iso-Bars" ??
Cub 1650: Look for the correct fix on page 3 of the Technical info the the Tractors and scan down about middle of the page and click on "Quietline Motor Modification" for a detailed explanation of this QL engine mount upgrade. Like Matt said...it is strongly recommended that you do this. Use the removed pan as a template...
Myron B
Old 09-12-2009, 11:29 AM
That's what I meant. These 15-hour days are killing me...
Old 09-14-2009, 03:05 PM
ajgross ajgross is offline
Inactive Member
While you're doing the craddle mod, you might want to think about pulling the engine on your 1450 and doing the mod to that one too. It seems to really help on these a bunch. You do it to your 1450 and you'll think you have a new tractor.
AJ
Old 09-23-2009, 07:20 PM
OK I have the mounts and the pan,is there a gasket that I need to place between the engine and the pan?(Or a gasket out of a tube?)....Just asking before I pull the engine this weekend..Thanks!
Old 09-23-2009, 07:34 PM
Yep, there's a gasket in there...any good Cub Cadet dealer should be able to get you one.
Old 09-24-2009, 01:19 PM
MFP8055 MFP8055 is offline
The 1650 I picked up earlier this year had exactly the condition described by MBounds: oil leak caused by mounting bolt wearing through the aluminum pan, caused by bad ISO mounts. I replaced the pan with a cast iron one, modified the engine cradle, and installed new ISO rubber. Plan on making these modifications to your QL. BTW I'm about 50 miles east of cub14501650.
IH 1650, CC 1210, 1610 and Bolens 1257
Old 09-24-2009, 03:42 PM
RPalmer's Avatar
RPalmer RPalmer is offline
You forgot to tell us how all that worked out.:biggrin2.gif:
Old 09-24-2009, 07:20 PM
Ok MPF8055 where did you get a cast iron pan?I was thinking the same thing,why don't they make a stronger aftermarket pan?(How much?)..Also,say you didn't replace the Isomounts and used metal spacers in it's place,other than doing obvious damage again to the flimsy oil pan,would that lead to other problems?Provided you mounted the engine exactly the same place as with the iso mounts.I know there would be alot more vibration..
