Old 04-01-2011, 03:18 PM
dieseldan123's Avatar
ok new development and not sure what this means. I tried the jumper wire on the solenoid and nothing happened. i then rechecked connection and got good readings. I then tried the same wire on the V/R to double make sure i had it polorized right. when i did this to the V/R the key was in the off position. when the jumper wire touched the Bat and Gen terminals the engine tried to crank (made one revolution).
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 04-01-2011, 03:20 PM
Originally Posted by JOHN SCHUTTE View Post
Correct me if wrong, but a 3 terminal solenoid grounds through the base. Is there bare metal on the dash tower to make contact?
I had forgeten about that area!
They are still available. Here is the current cub number and cost:
Attachment 9796
Sweet! Ill pick one up next week!
Originally Posted by william1041200 View Post
my friend's 123 is at my house, it has an amp gage mounted to the steering tower. It stuck in my mind, as a normal thing.
Thats the same area i plan to mount mine. want it running right before i do add it.
