Old 03-14-2013, 08:44 AM
restore49 restore49 is offline
Use the pump you reference -build a solid mounting bracket on front of Sunstrand unit mount pump ABOVE with pulley facing rear - make a pulley or chain drive on front of Sunstrand. Shorten drive shaft install fabric coupler and fan. May have to build a tunnel cover with a slight hump. A pump from older Fisher plow and control may fit (they had a free wheel pin when not in use? Be very cleaver if an electric clutch could be fitted to your pump
Old 03-14-2013, 09:29 AM
Or - maybe extend the shaft on the back of the Sunstrand pump and mount the unit where the battery goes or behind the seat? This would eliminate side load
Old 03-14-2013, 09:38 AM
Scott Murphy added a Hydraulic Lift assembly (auxiliary pump) to a 1806 and did a nice job of custom fabrication.
Old 03-14-2013, 12:14 PM
It was a work of art!
Old 03-14-2013, 01:07 PM
It sure was!
