Old 12-30-2010, 11:38 AM
This is why most of the weight on my loader tractor is on the wheels. I suspect that counterweight contributed to the failure. There is a pretty massive stress concentration where the flange attaches to the axle, and having weight on the frame/rearend increases the stress on the axle flange.
The rear will have to be drained and the axle pulled and replaced. I would replace both axle bearings and seals while you're in there if I were you. You should also get some wheel weights or load the tires, and reduce the side of that counterweight, or you may have this happen again.
Matt,
Don't you think the welded flange instead of a forged flange also contributed to the brittle/weakness of the axle assembly?
I'm thinking that a forging would of not broke, but either design would be overstressed in my book @ that small of diameter with the loads imposed.
Old 12-30-2010, 03:18 PM
Merk Merk is offline
by Matt G.
and
by ol'George
Matt,
Matt is correct on what cause the failure. 150 to 200 pounds of weight would have been plenty. The loader itself is lucky to lift 350 to 500 pounds. When you add the operator's weight, rear end weight you will have more than enough counterweight. Going overkill like some of the recent post/topics will cause problems like broken axles or diffs. I rather have my Cubs be able to spin tires some than over do the weight.
George-
A forge flange may take more abuse.....they do cost more and not needed if the driver/owner use some common sense.
Old 12-30-2010, 04:10 PM
B-Brush B-Brush is offline
Jeff K
Thanks for posting and dont feel bad i did the same thing to my cub 100 on the first snowfall we seem to forget when playing with these things that they are not TANKS lol they will break good thing they are not too bad to work on good luck !!!
Old 12-30-2010, 04:21 PM
and
George-
I couldn't agree more as far as cost and given the original intent of the welded design.
Just like the weights I hung on my axle for traction, I was leery of them because they were not only excessive, but hung so far back, multiplying the weight/stress.
I just wanted to see how it would work. I really don’t use the 782 for snow removal.
I use my IH 400 loader/rear blade tractor as it is faster, and better suited.
The 7’ bucket moves a lot of snow in hurry as well as the rear blade.
But what fun are little toys if a feller don’t at least try to play with them Ha,LOL!
The 782 came with chains and a thrower so I thought I'd play some before I moved the thrower along to my son.
Old 12-30-2010, 04:30 PM
Ol'George-
Absolutely...the weld is probably more brittle and therefore more prone to cracking from repeated loading. There are probably residual stresses in the axle flange joint area as a result of the welding.
Old 12-30-2010, 05:25 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Default loader update
The axle is fixed good as new. Price wasn't that bad for a used one. I have only only owned this tractor for a few months now. I haven't really beat on it. I was just playen in the snow when it happened. It was definitely broke before i bought it. I feel like u guys are scolding me for having to much weight on the tractor. I like the idea of putting fluid in the tires ,but the tires are pretty shot. I will wait till i get new ones them i will fill them. As far as wheel weights that is a great idea but all that i own are being used I will be looking for some more this summer at tractor shows.This will help me redistribute the weight properly Thank you all for your concerns,comments,and opinions they will be put to good use.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 12-30-2010, 07:46 PM
by jeff k.
My comments were not intended to be scolding.....I see too much of that-someone thing a little is ok....so alot should be better. I've found out the hard way (spinning tires on rims and junk a diff carrier) that more is not always better.
Old 12-30-2010, 08:01 PM
I hope everybody else that has a giant concrete block hanging off the back of their tractor is paying attention to this. It's not a matter of if an axle will break, but when. The later tractors with fine-spline axles and aluminum rearends will be just as susceptible to this.
