Old 10-26-2010, 02:43 AM
Great pics Jay! Is Oct. paint your cub month? hehe Thanks for sharing your pics.
Old 10-26-2010, 04:39 AM
nikster's Avatar
nikster nikster is offline
Just curious why you didn't paint the inside of the rims? A tire will seal best against a clean, painted bead. That rust is eventually going to spread and probably mess up your new paint. Also, I'd wait more like a week before mounting the tires to give the paint a better chance to cure.
I was told this also. If anything my buddy told me to at least sand the rust & primer it. Makes sence? DUNNNNNNO?
Nik
Old 10-26-2010, 01:31 PM
Hubman's Avatar
Hubman Hubman is offline
Jay , your painting looks like it came out nice , you had a nice warm day for it.
Hey , did you try to get your paint from a IH-Case dealer in Somerville NJ .
Reason I ask a few weeks back I called them and said I was the second guy to call in the last week about Cub Cadet paint . They were pretty short with me and said they don't carry paint for cub cadets.
Old 10-26-2010, 07:57 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default Yes
Yes I qctually did call them. They were kinda rude. I bought some yellow at a local spot and some other at depot. Appliance epoxy almond from rustoleinum is a darn close match to the white on my 127. It's almost exact and is less than 5 nix a can. It also goes on thick and does not run. I got some pretty even coats with no runs on the rims and the seat pan.
Old 10-26-2010, 09:17 PM
Lmercer Lmercer is offline
Lookin' good
Old 10-26-2010, 11:20 PM
Mizar N68X Mizar N68X is offline
Yes! Looking good!!!
Do you have a blast cabinet?
I'm doing a 70 and it's coming along nicely.
Old 10-27-2010, 04:56 AM
nikster's Avatar
In another post I asked if anyone used that epoxy spray paint. NO REPLIES, your the first, I also am using it to paint my gas tank. My # 122 is devoid of paint & it's yeller. My # 109 tank is Cub white, so i'm going to paint both tanks with the epoxy paint. Who is going to tell me that hey, the tank color on the # 122 should be yeller?
I'm doing this because of past posts & the comments made about newly painted gas tanks & the problems of having gas dripped & spilled on fresh paint.
Nik,
Old 10-27-2010, 05:49 AM
Nik,
That paint works well. If you go to their website it says that if you have bare metal that you should use primer that's what I did I used a automotive primer and the paint covered well. I also put some auto body heat lamps on It for a few hours but the parts I did not do that to took about 48 hours to cure good. You will probably want to wait at least a week before using the gas tank. I also painted a piece of metal that once the 1 week recommended dry time before recoat time is up I am going to try and clear coat and see how that works too.
Old 10-27-2010, 08:49 AM
nikster-
I replied to your post 2 days ago or so...
Old 10-27-2010, 11:27 AM
Hubman's Avatar
Default Whole thread on subject
Nik,
Nik , there is a whole thread devoted to rattle can spray paint . In the restoration tips section . I could not find Epoxy paint in Yeller , but I would bet the Rustoleum almond epoxy would hold up to gas and oil spills . I would use the Yellow spray can over a good auto primer . Your tank certainly could use some paint , then report back to us how it holds up.
http://www.onlycubcadets.net/forum/s...ead.php?t=6275
