Old 10-25-2010, 04:16 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default Little sanding and painting
Well I have some time off this week so I figured it was a good time to do some cub cleaning and painting. I took the front rims off finally and sanded, primed and painted them today and also did the same with the seat pan. Hopefully the 127 will start to spruse up now. Next up is the fender pan and the hood.
seat pan all primed up (one spot is wet, I did not get a spot of the sy=ticker off, so had to redo that spot)
Painted
Rims all sanded and primed
And the rims painted, tire mounting tommorow!!!
More to follow tommorow !!
Old 10-25-2010, 05:03 PM
Looks awesome, Jay!
Old 10-25-2010, 05:29 PM
Thanks man. I am trying!!!
Old 10-25-2010, 06:37 PM
Just curious why you didn't paint the inside of the rims? A tire will seal best against a clean, painted bead. That rust is eventually going to spread and probably mess up your new paint. Also, I'd wait more like a week before mounting the tires to give the paint a better chance to cure.
Old 10-25-2010, 07:12 PM
Default Thanks Matt.
Actually the inside of the rims are discolored but there is no rust. They were in great shape. There were a few small rust spots that I did sand and paint. The paint will be ready tomorrow I have body shop heat lamps on it that I borrowed from my buddy.
Old 10-25-2010, 07:22 PM
I would paint the inside of the rims,you don't want problems later.Can't do em once the tire is mounted.
Hidy Ho
Old 10-25-2010, 08:49 PM
The only 'discoloration' I see in there is rust-colored. That's going to come back eventually.
Old 10-25-2010, 09:00 PM
Default ok
thanks for the concern......
Old 10-25-2010, 10:11 PM
JaysNJcub127
Nice work on the paint
I have already done my front rims. But i need to do the seat.
Old 10-25-2010, 10:16 PM
Default thanks
JaysNJcub127
I have a new seat pad, so I figured let me get the seat painted with the rims since I have the replacemt seat cover and new front tires.
