Old 10-10-2018, 07:19 PM
Originally Posted by john hall View Post
I think the tunnel cover is held on by #12 (probably 24 pitch). Don't quote me on that. It is a RARELY used bolt. For that reason, when folks lose them they tend to shove whatever sheet metal screw/wood screw they had in their that they could make tighten down. I would think that the parts book would tell you exactly, or if you click on a part, you should get a more exact description.
You’re correct John. This screw size is used quite a bit on our cubs and for some reason everyone wants to convert to 1/4 x 20 or jam a self tapper in. Im now hearing the sirens of the correct police in the next room.
Old 10-10-2018, 07:40 PM
I used a few NOS ones on the tunnel cover of the 1512, they were black though...
Up to 534 and counting...
Old 10-11-2018, 07:16 AM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Huh, you guys shoving any kind of sheet metal screw in, but mine was fancy and still had the original bolts. They're going to be swapped out for hex nuts, because a)They're a weird size and b)I lost them.
Here's what I got so far:
12-24 x 3/8" tunnel cover hex bolts
10-32 x 3/8" muffler box bolts
1 premium 1.5" muffler clamp U bolt w/ 2 nuts
10-32 x 1/2" baffle bolts (into the engine sheet metal)
3/8-16 2 1/4" partially threaded cradle bolts
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 10-11-2018, 08:07 AM
I got tired of those Tunnel Cover bolts vibrating out and then looking for that odd 12-24 size. I drilled and tapped mine for the common 1/4-20 size. Real happy.
