![]() Quote:
voting for the hose as well. I worked with a guy 25 years ago that drove an old Subaru. He was replacing brakes every 2 months, at least. Finally someone told him it was the brake hoses--problem solved. My guess is they are pretty cheap and if yours have some age on them, well lets just say it ain't no fun when one blows.
Any news on this?
I gonna put my money on a caliper hanging up and a close second will be brake hose.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
He replaced the caliper and the new one is hanging up. Almost has to be the collapsed internally hose.
Whoops, didn't see there was a second page to this or much interest! I have a new brake hose waiting for me to pick it up at Napa after work tonite. So I'll throw that on this evening and see if that helps. I'm really crossing my fingers as after a caliper and hose replacement, remaining options aren't very cheap. Thanks again for the advice guys!
-Ryan
Many times the brake hose has a steel mounting bracket crimped around the hose on some models, especially Ford Ranger pick-ups. I have seen rust cause the steel bracket to swell and crush the hose preventing flow as discussed. Other than the rusty mounting bracket, the hose often looks fine.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
I would suggest you need to bleed it more if a bubble of air is in the cool side that would do it , does the r side drag maybe the first question .
you can cut the power to the ABS if you think it is firing up ( for a test drive )it has happened ,usually you will hear it though it is sometimes tough to get the air out of ABS systems , Rotors are in very good condition ? it is a common problem for the pad to corrode the rotor then cause a rough braking . hope it helps |
![]() Quote:
![]() ![]() To cut the power to the ABS, I'm guessing you mean by just pulling the fuse for that subsystem? And the rotors were replaced last time I did brake pads (a year ago, year and a half maybe?). They should be in good shape ![]()
-Ryan
![]() Quote:
-Ryan
