Old 01-14-2017, 01:31 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
We have the three turn CCC boxes on a 1450 and a 128... The range of travel on the steering arm seems to be the same.. the effort required is alot less.. My mom asked if we had put power steering on the 1450... she loves it..
I would highly recommend it on any older cub!
Jay
Proud owner of the following:
Old 01-14-2017, 01:55 PM
1811 and similar models had the 3 turn box, yes it will fit in your 149.
So what models are "similar" to an 1811?
Old 01-14-2017, 02:57 PM
1050, 1204, 1210, 1211, 1806, 1810, 1811, 1812. these are what i can think of off the top of my head.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-14-2017, 07:56 PM
Thanks Tim.
Old 01-14-2017, 09:10 PM
Yes thank you, I have a super steer axle all ready to go, new drilled and tapped zerks, new rod ends and was wondering if travel was the same...Now that I think of it the wheel does sit higher on my 1250 vs my 169...That was made mostly of junkyard parts too, I'll have to see if it's a 3 turn.....Both turn with one finger but I have ribs on them and like to add more camber...
Thanks for the answers guys!!!
Old 01-20-2017, 09:21 PM
Shotgun Clay Shotgun Clay is offline
Would a 1720 cub steering be a 3 turn? I found an add on a parting out cub...
Clay
149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart
Old 01-20-2017, 09:26 PM
The 1720 is a lawn tractor, it's much smaller and the parts won't fit a gt.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-20-2017, 09:27 PM
The I'll keep lookin. Thanks for your response
Clay
Old 01-21-2017, 11:51 AM
jaynjeep's Avatar
Clay,
I have bought several 3 turn CCC. Good luck with your project!
Jay
Old 03-15-2017, 04:39 AM
bejack bejack is offline
Default bejack
I'm gonna get killed here, but i gotta confess. First, you gotta know I kept the Cub parts.
The Ross steering box from a green tractor - 10 or 12 horse - forget now what the model no is - maybe a 210 or 212 - will fit with a little work. And they were not hard to find a few years ago. It gives you the 3 turns. It is a big help but not quite power steering. I found it a welcome improvement.
The shaft is longer than a 129 or a 123 but the screw fits right in the cub box. Watch the bearings - they are different and you must match the races but there is enough parts between the two to do the job.
The box from the green rig mounts different so I bent a couple of bars to modify the fit and use the larger box on one of my Cubs.
Remember - I kept the original Cub parts so they can be restored someday.
