Old 09-20-2015, 07:43 AM
Yeah great find and great price also. Cradle mod and new ISO mounts and you're in business. You going to rebuild the engine to take care of the smoking?
Old 09-20-2015, 10:15 AM
I dunno, maybe its just the fact you cant see the engine making it look hard to work on. Engine has to come out, smokes pretty heavily except at idle. You can tell it is a 16, man it has some torque.
https://www.youtube.com/watch?v=Pn_Z...ature=youtu.be here is the video he posted on the ad look down to the left and right you will see some smoke. He was pretty good at filming so it didn't show as much as it does in person, lol.
Old 09-20-2015, 10:52 AM
Shop smells like gas this AM, no puddles underneath, cranked right up. Lights wont come on but all work with a jumper wire. Still cant believe the hydro is clean and dry underneath, even the release valves are dry.
Carb has half throttle to wide open, dies at idle. I'll look at engine mounts at the parts store I used to run, I'm thinkin of trying bird legs mounts rubbers Chevy used in the late 50s early 60s n the front of V8s, they are softer than the Moog sway bar rubbers.
I really didn't have the $$$ to spend for this right now, prop taxes are due 10th next month and need a tank of propane for the shop heater, but had to have a 1650 that was Lew priced and 5 miles away.
Old 09-20-2015, 12:49 PM
Terry C's Avatar
Terry C Terry C is offline
Sounds like carb is messed up. If you get that working better might help the smoke problem. I would do that, change the head gasket, change the oil .
if you can't hear knocking sounds, I say it's worth messing with and you don't have to spend much money to try
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 09-20-2015, 12:52 PM
bkw3614 bkw3614 is offline
Quietline looks hard to work on
Quietlines aren't that hard to work on. If I can figure them out, most people should have no problem.
I agree with everyone who has recommended the replacement of the ISO mounts. Do the engine modification and change the mounts. When I changed the mounts in my 1250 Nightmare, I used the genuine Cub Cadet mounts and haven't been sorry. Once they were properly adjusted, the tractor is a sweet machine.
You have yourself a sweet machine! Plenty of power, rare dual stick option and, IMHO, the prettiest Cub Cadet ever built. You got a great deal! Congratulations.
Old 09-20-2015, 05:55 PM
twoton twoton is offline
Great find there Brian, congrats!
Old 09-20-2015, 08:40 PM
Thanks guys. Pulled the broken muffler box off today, muffler has fell off, might be repairable, PTO works, head gasket leaking all across the front. May pull the head and look. Carb is definitely leaking, is the kit the same for #26 and 30? If so I have a kit on hand. Still no power to lights or PTO, haven't pulled the tank yet-this is the first one I brought home that already ran when I brought it home. Drove it up in the truck.
Old 09-20-2015, 09:23 PM
check the fuses for blowidge,nice find though...
Old 09-20-2015, 09:24 PM
mortten mortten is offline
Carb kit is KH-25-757-02
Old 09-20-2015, 09:32 PM
I checked fuses first, one was cracked/broken replaced it still nothing. Have power to one all the time the other is hot with the key on.
