Old 11-26-2014, 08:18 AM
steved steved is offline
I'm researching the torque values and bolts on the head before I take it apart and have a question. The 105 manual says to torque to 420 in-lbs which is 35 foot-lbs. In the K241 manual it says 25 - 30 foot-lbs.
Old 11-26-2014, 09:47 AM
mickb72 mickb72 is offline
Default cub
Hi, i use copper kote and go to 30 but i know some people who go to 35. Mike
Old 11-26-2014, 05:26 PM
charlie105's Avatar
charlie105 charlie105 is offline
Wait , what--- a brass screen ? I understood it's a vent , just thought it was a solid plug that could vent. Mine is painted over (PO). Can it be removed for clearing the screen ?
Old 11-26-2014, 05:29 PM
Looking good steved.
The hardest part is not scratching the paint during reassembly.
Up to 534 and counting...
Old 11-26-2014, 05:36 PM
Thanks for the response. I got the head off and here are the pictures. This is my first time on an engine so I need some opinions. How bad or good is this? I see the one burn mark in the head. I realize what I have to do to put it back together but other than gently scrape and vacuum what else. Thanks! Oh, and the brown dirt on the edges of the head are what we down south call dirt daubers!
Old 12-01-2014, 01:56 PM
Two questions. The nut holding the engine pulley on, is it a right or left hand thread. Reasoning tells me, I could be wrong, it is a left hand since the motor rotates CW from this angle. I didn't want to put a lot of pressure on it without being sure. Also I've noticed when we rotate the shaft, the two rods that go up and down and push the valves open, sorry not sure of the proper name, do not come back down in the same position. They rotate a little bit each time they come back down. Is this normal? Bear with me, first time in an engine. Thanks!
Old 12-01-2014, 02:38 PM
The nut is standard right hand threads. As for the things that lift the valves, there called lifters and yes they will spin freely.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-01-2014, 02:43 PM
Thanks for the help. I'll go back out there and use a cheater bar!
Old 12-01-2014, 02:53 PM
If you have a impact gun I'd use that, doing it by hand doesn't work the best unless you can stop the engine from spinning.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-01-2014, 02:55 PM
Got one, I'll try that.
