Old 09-29-2014, 09:26 PM
Nick,
Get rid of that stupid brass thingy and put the correct fiber one on.Most pto baskets are about a 1/16 away from the sg bolt,no locking washer is to be behind it.
Old 09-29-2014, 09:36 PM
Nick,
That "brass thingy" lasts a lot longer than a fiber button plus doesn't break off when changing belts.
Old 09-29-2014, 09:42 PM
yes but on a 100 there is very little room for it to clear the grill.
Old 09-29-2014, 09:45 PM
That's why I make them the same thickness as factory
Old 09-29-2014, 09:54 PM
Do the brass ones go clear through and out the other side with threads? Looks like Nikodemis has a nylock nut holding it on? I was under the impression they were all press fit?
Old 09-29-2014, 10:06 PM
I also think the PTO isn't far enough on. The fiber buttons work just fine for me...
Old 09-30-2014, 07:20 AM
I believe my problem is that I don't have the pto holes lined up with the basket pulley slots, key way is flush, there is a lock washer on the bolt but it always had one.
Old 09-30-2014, 08:18 AM
Nick
The bearing is not on the shaft far enough. It needs to be flush with the end of the shaft.
Lew
The brass button is not the problem. I have one on my 149 and it works just fine. It's dimensionally the same as the fiber POS.
Nick
Read this.
http://www.onlycubcadets.net/forum/showthread.php?t=9
Old 09-30-2014, 10:21 AM
Yes but on a 100 the grill is close to the pto arm as it is, the nut puts it that much closer and harder to put on the belt.
Old 09-30-2014, 10:22 AM
The brass button is a press fit just like the fiber button. Nick must have added the nut.
