Old 03-11-2014, 03:08 PM
IsaacSchuler's Avatar
IsaacSchuler IsaacSchuler is offline
Ok..... why did you buy another trans? Those never go bad. Is it because you broke that brake arm? If so, why didn't you just change out the broken part?
The tires/rims you put on the front have no bearing in them. If you leave them on there you will wear out the spindle in no time flat. Why does the left spindle have a threaded rod sticking out? Did you put that on there?
I replaced it because the part wouldn't come off so it will be a parts transmission. And the other one was 50 dollars.
And the previous owner stripped the threads and welded a bolt to the end. And the tiller tires that are on it are temporary just to move it around i still need to find the right tires.
play like you're in first work like you're in second
My Facebook Group
Old 03-11-2014, 03:15 PM
Originally Posted by TheSaturnV View Post
Isaac,
A wire wheel would be a better choice for paint prep and cleanup than a hard disc on an angle grinder. You can get a simple one for around $5 that will chuck in the end of an electric drill.
When you run into a thick paint blob or run, take a small hammer and something like a nail punch to them. I used a welding slag hammer and chipped away at the runs, pick axle style. A couple of good hits and the paint will fly off the metal in chunks, so wear your safety glasses.
Heads up, if you replaced that entire rear end because of the broken brake arm/lever, there likely was nothing wrong with it. The rod the brake lever/arm pivots on is removable and it can be replaced. I doubt you're ever going to have a need for those individual parts you are planning to soak in oil. You might consider getting that thing back together, maybe with a local Cub nut's help.
I'm using a wire wheel at the moment and I was using the angle grinder on the rust spots. The brake arm wouldn't come off i tried hammer and it wont come off so im keeping it for parts. And i've played this game before if i sell the parts the parts i sell break and i have to buy them again so im going to keep them. And i have no one where i live who likes cubs and there are no dealers by me.
My Facebook Group
Old 03-11-2014, 03:16 PM
Thanks for the update, and keep up the good work!
Thanks Alot
My Facebook Group
Old 03-11-2014, 03:18 PM
Originally Posted by Mr.Goffena View Post
If you were having an issue installing the motor on the frame rails I am going to assume that you did not do this mod. http://www.onlycubcadets.net/forum/s...ead.php?t=4630 This mod should be done to every quiet line tractor when the engine is pulled. Also as for the carb I soaked my carb in white vinegar for a few hours and used a brass brush on it. It was shinning like it was new.
I let my carb soak in kerosene and scrubbed it down with an sos pad. And i dont want to modify my tractor i want to leave it the way it is.
My Facebook Group
Originally Posted by IsaacSchuler View Post
Thanks Alot
Anytime!
Old 03-11-2014, 03:34 PM
Smile
https://www.youtube.com/watch?v=dSp0XeTJwVE
My Facebook Group
Old 03-11-2014, 06:39 PM
TheSaturnV's Avatar
Keep rollin', it's going to be done before you know it.
Old 03-11-2014, 06:42 PM
Yeah i can't wait
My Facebook Group
Old 03-11-2014, 10:29 PM
Awesome vid!
Old 03-11-2014, 10:42 PM
Awesome vid!
Thanks Alot
My Facebook Group
